I am familiar with metasys and with n4
first time using Facility Explorer and cant seem to find where to Launch PCT
im suspicious that i may need to be using FX Pro - is there a way to confirm this?
the software is called FX Workbench 14.12.3
There is a way to confirm it, and it is a file check rather than a menu hunt. A Workbench Tools menu is assembled at startup out of what the install declares, so your own install can tell you whether PCT is there at all.
Measured on the Niagara 4.15.5.22 install in front of me, with javap over the shipped classes: the menu is built by WbCommands.buildToolCommands() in workbench-wb, and three gates decide what reaches it, in this order.
BWbTool.getInstalled() asks Sys.getRegistry().getTypes(BWbTool.TYPE) - that is, the <type> entries the installed modules declare in their META-INF/module.xml - and skips the abstract ones (BWbNavNodeTool, BWbService, BWbTool here).getLicenseFeature() then Feature.check() is called on it. The whole loop body sits inside a catch (Exception), so a tool whose feature is not licensed just does not appear: no error, no log line. Worth knowing that on this install 0 of the 27 tools override it at all - the base returns null - so on stock modules this gate never fires, though a vendor’s own tool is free to use it.BWbProfile.hasTools() and BWbProfile.hasTool(TypeInfo) filter what is left. The base class returns true from both, but profiles override: here BWbWebProfile and BWbPopupProfile return false from hasTools() outright, and BKioskProfile, BAlarmPortalProfile and BPlatManagementProfile return false from hasTool() for every type.So a tool you cannot find is one of three things: the module is not installed, the licence feature is missing, or the profile excludes it. The first is checkable with no station and no licence:
cd "<your FX install>/modules"
for j in *.jar; do unzip -p "$j" META-INF/module.xml 2>/dev/null \
| grep -o '<type class="[^"]*Tool"[^>]*' | sed "s|^|$j |"; done
On this install that prints 27 lines from 12 modules, e.g.
platform-wb.jar <type class="com.tridium.platform.ui.license.BLicenseDatabaseTool" name="LicenseDatabaseTool"/
Treat it as a way in rather than as the list. I also walked the superclass chains in the class files, which gives 27 concrete BWbTool subtypes out of 9,345 declared types across 756 module jars, and against that the grep above includes 6 things that are not tools (a PX enum, a view, a wizard agent) and misses 6 that are, mostly because the order of the class and name attributes varies between modules. Grepping for the acronym is worth a go as well, but look at what matched: grep -i pct over the same files hits 4 modules here and every hit is a substring of an OPC class name, BOpcThreadPool and friends.
If nothing in your modules folder declares it, that is your answer - no licence string or profile setting will conjure a type that is not installed, and it ships in a different package. If something does declare it, you are on gate 2 or 3, and the type name gives you a way to poke it directly: workbench-wb declares the tool: ORD scheme (BToolScheme, ordScheme="tool"), and tool:<moduleName>:<TypeName> resolves through BTypeSpec.make(...).getInstance() - for example tool:platform:LicenseDatabaseTool, where moduleName is the module.xml attribute of that name (platform), not the jar name (platform-wb). That path covers the nav-node tools only, 17 of the 27 here.
One caveat I would rather say than have you discover: all of the above is measured on 4.15.5.22, not on FX Workbench 14.12.3, which I do not have. The commands read your install rather than mine, which is the point of them - but if yours is an AX-era build, expect some class names to differ, and treat my counts as the shape of the answer rather than as yours.
