Is there a way to generate pdf of an entire stations wiresheets? Other than going into each folder and export, pdf, save to file etc
Not naturally. A program object could probably be made. Is this for a submittal requirement?
Thanks Charles. I come from a TrendSET background where you can print the wiresheets.
I’ve always kept hard copies, it’s also quite handy to reference without needing to spin up a station, or show the new guy a specific thing especially out in the field.
I’m going to my laptop. Let me see what I can come up with.
So looking what it would take, a program object I don’t think is possible. It would have to be in a module. Just of curiosity, why would you just have a standard station with a bunch of logic in there for techs to reference?
thanks for looking into that Charles. Taken a few new sites as maintenance and all from separate companies so no “default” logic between them. Eventually you learn each one but sometimes I’m not the engineer on site so it can be helpful to have a reference that is easy to access from a sharepoint.
I understand. Yeah, unfortunately, it just needs to be in a module. It wouldn’t be difficult to do so, but as a regular program object, it’s not really feasible.
I think a bigger challenge is that logic can be nested/composited within objects or other folders and you might see the handle for a link, but not any of the logic on the other side. I’ve always just kept backups of stations and opened offline if I needed to walk someone through something
