I am using the Rotational Load Sequencer to manage the rotation of three pumps. what is the best way to display the currently selected duty pump on the Niagara graphics?
You might be able to do a string compare or something and check each pump versus the out of the Lead Load Enum. If the string matches whichever pump is lead (A, B, C, etc), you could display “Lead” by that pump
Thanks for your reply and time, will follow the same and update you.
