BS: properties().setValue("name", val) not working as expected
Hi, as the title suggests I am having unexpected behaviour using setValue in BajaScript.
Previously I had my component where the code below worked fine. However now I am doing it with a string and it wont work fully. I am able to set it, but as soon as I refresh my browser I am back to the old initial value again, could there maybe be something blocking this save?. Is there anyone with a similar experience and with a potential fix?
$('#color-picker').on('change', function() {
	const selectedColor = $(this).val();
	widget.properties().setValue('color', selectedColor);
	updateSvgColors(selectedColor);
Thanks!
Where did you add your property to the widget? In the constructor?
Yes it is added like a normal default property as such:
defaults: { propName: { value: '', type: 'baja:String' } }
