I spent some time figuring out how to implement custom dialog notifications in the ddctCommunity-rt module part for logging plugin messages and thought it might be useful for others
. This allows you to log results the same way running a robot does. However you can customise the dialog layout with BWidget elements however you please.
Here’s a quick reference guide:
Raising the Notification
To raise a custom dialog notification, you can use the following code snippet:
BDialogNotification notification = new BDialogNotification();
notification.setDialogTitle("Alarm Extensions");
notification.setDialogMessage("Your message or log results......");
notification.raise(false); //If you do not set false the notification will be raised to all connected clients.
BDialogNotification for Module -rt Part
To create a BDialogNotification for the -rt module part, you can define the notification class as follows. This allows assigning the agent view from the -wb part.
package com.ddccommunity.ddctCommunity.notifications;
import javax.baja.nre.annotations.NiagaraProperty;
import javax.baja.nre.annotations.NiagaraType;
import javax.baja.util.BNotification;
import javax.baja.sys.Property;
import javax.baja.sys.Sys;
import javax.baja.sys.Type;
@NiagaraType
@NiagaraProperty(
name = "dialogTitle",
type = "String",
defaultValue = ""
@NiagaraProperty(
name = "dialogMessage",
type = "String",
defaultValue = ""
public class BDialogNotification extends BNotification {
//region /*+ ------------ BEGIN BAJA AUTO GENERATED CODE ------------ +*/
//@formatter:off
/*@ $com.ddccommunity.ddctCommunity.notifications.BDialogNotification(1009021973)1.0$ @*/
/* Generated Mon Aug 05 14:24:20 AEST 2024 by Slot-o-Matic (c) Tridium, Inc. 2012-2024 */
//region Property "dialogTitle"
* Slot for the {@code dialogTitle} property.
* @see #getDialogTitle
* @see #setDialogTitle
public static final Property dialogTitle = newProperty(0, "", null);
* Get the {@code dialogTitle} property.
* @see #dialogTitle
public String getDialogTitle() { return getString(dialogTitle); }
* Set the {@code dialogTitle} property.
* @see #dialogTitle
public void setDialogTitle(String v) { setString(dialogTitle, v, null); }
//endregion Property "dialogTitle"
//region Property "dialogMessage"
* Slot for the {@code dialogMessage} property.
* @see #getDialogMessage
* @see #setDialogMessage
public static final Property dialogMessage = newProperty(0, "", null);
* Get the {@code dialogMessage} property.
* @see #dialogMessage
public String getDialogMessage() { return getString(dialogMessage); }
* Set the {@code dialogMessage} property.
public void setDialogMessage(String v) { setString(dialogMessage, v, null); }
//endregion Property "dialogMessage"
//region Type
@Override
public Type getType() { return TYPE; }
public static final Type TYPE = Sys.loadType(BDialogNotification.class);
//endregion Type
//@formatter:on
//endregion /*+ ------------ END BAJA AUTO GENERATED CODE -------------- +*/
public BDialogNotification(){}
Custom Notification Handler
The custom notification handler processes the notification and displays it in a dialog. Below is the code for the handler and goes in the -wb module part:
package com.ddctalk.ddctCommunity.ui.dialogs;
import com.ddccommunity.ddctCommunity.notifications.BDialogNotification;
import javax.baja.nre.annotations.AgentOn;
import javax.baja.sys.Context;
import javax.baja.ui.BDialog;
import javax.baja.ui.pane.BTextEditorPane;
import javax.baja.ui.text.BTextEditor;
import javax.baja.workbench.BWbShell;
import javax.baja.workbench.util.BNotificationHandler;
@NiagaraType(
agent = @AgentOn(types = "ddctCommunity:DialogNotification")
public class BDialogNotificationHandler extends BNotificationHandler {
//@formatter:off
/*@ $com.ddctalk.ddctCommunity.ui.dialogs.BDialogNotificationHandler(2581040743)1.0$ @*/
/* Generated Mon Aug 05 14:24:17 AEST 2024 by Slot-o-Matic (c) Tridium, Inc. 2012-2024 */
//region Type
@Override
public static final Type TYPE = Sys.loadType(BDialogNotificationHandler.class);
//endregion Type
//@formatter:on
public BDialogNotificationHandler(){}
@Override
public void handle(BWbShell shell, BNotification notify, Context cx) {
BDialogNotification item = (BDialogNotification)notify;
BTextEditor textEditor = new BTextEditor(item.getDialogMessage(), false);
BTextEditorPane textEditorPane = new BTextEditorPane(textEditor, 20, 80);
BDialog.message(shell, item.getDialogTitle(), textEditorPane);
Summary
- Raising the Notification: Use the
BDialogNotificationclass to set the title and message, then raise the notification. - Custom Notification Class: Define the
BDialogNotificationclass in the -rt module part with properties for the dialog title and message. - Notification Handler: Implement the
BDialogNotificationHandlerclass to handle the notification and display the dialog in the agent view from the -wb part.
