Is there a way to customize existing widgets in niagara workbench. Specifically, I’m trying to get the Tabbed panes to look different. Rounder corners and custom backgrounds.
There is but I will require you to put it in a module. You can find all the code and put it in a module and create it. However, decompiling Tridium’s code does go again the agreement you sign when you install Niagara.
well.. thats too bad.
Modules are encrypted for security reasons. So you can’t modify them any more like you could in Niagara AX.
I’d never do this.. ![]()
Correct. I wouldn’t modify existing modules. I used to in AX but not here.
Yeah I totally never would ever have a look at tridiums code never. ![]()
