Hello!
My name is Charles. I’m a moderator here. I’m also a certified Niagara Instructed and certified Niagara Developer. I work for a building automation vendor as their lead trainer and technical engineer. I’ve been in the controls industry for 31 years. Here’s my advice:
The fact you already have HVAC knowledge is great! The fact you also have computer skills is also fabulous! In the controls industry, we have to wear multiple hats at the same time. We have to wear the mechanical hat because we need to understand how our controls work and how the equipment we are controlling works. We need to understand the electrical side to make sure we don’t let the smoke out of our controllers, and yourself. The third side now that’s become extremely important is networking. We need to know how to connect our product to the web and such.
You don’t need to buy any controls yet from ebay and such. The reason being is that it may not be a product you work with. There are a variety of products that are great. However, the company is the most important part.
It may be hard to find your home in the controls industry. It’s not uncommon for a controls technician, programmer, etc, to have worked for 5-6 companies (or more). It’ll have to be a values kind of thing. Find a company whose values align with yours and that will usually make a good fit.
https://www.dropbox.com/scl/fo/24qbclnst7x793ceucegt/AKYuYlWl6HAjbvp0gERp8f4?rlkey=hgxo7fnd53np60ycjfxme9i4l&st=n88q36mh&dl=0
That’s a dropbox link to come Controls Books. One is the Gray Book as it’s known in the industry. The Controls Gospel if you will. Another is one my friend wrote and it’s fabulous. I will put more books in there and probably create a category for Controls Books that I’ve acquired over the years.
There are plenty of controls companies out there. Another point of contention might be salary. Some companies don’t pay well to start out, but I think with your knowledge and already working in residential, you should be able to make up the difference fairly quickly.
In addition, Once you find a company you like, see if they have some extra controllers that couldn’t be RMA’d and such. So maybe they have bad inputs or outputs, but they can still be programmed and such.
The reason why I’d hold off on buy them outright is you may start out with a company that does Niagara, and then you go work for an Automated Logic Dealer and then never touch Niagara again.
