We have 200 BACnet devices on the same network number, each with a unique device ID but sharing the same IP. I need to distribute these devices across three JACE 8000 controllers, all using the same network number and IP to retrieve data from the field. If I add them directly using BACnet Discovery Manager on each JACE, will this lead to communication conflicts or issues?
The above is already implemented and getting below issue
“ SEVERE [01:14:13 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(4): Possible router loop, or duplicate network number 11
SEVERE [01:15:53 26-Mar-25 IST][fox] Failsafe timeout on read 436000ms > 60000ms
SEVERE [01:15:54 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(4): Possible router loop, or duplicate network number 11
SEVERE [01:18:31 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 8!!!
SEVERE [01:19:12 26-Mar-25 IST][fox] Failsafe timeout on read 64860ms > 60000ms
SEVERE [01:19:21 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (281ms) indicates possible router loop on network 10!!!
SEVERE [01:19:41 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 17!!!
SEVERE [01:20:30 26-Mar-25 IST][fox] Failsafe timeout on read 70219ms > 60000ms
SEVERE [01:20:29 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 1!!!
SEVERE [01:21:01 26-Mar-25 IST][fox] Failsafe timeout on read 71625ms > 60000ms
SEVERE [01:20:49 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (297ms) indicates possible router loop on network 2!!!
SEVERE [01:21:17 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 12!!!
SEVERE [01:21:30 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (297ms) indicates possible router loop on network 4!!!
SEVERE [01:21:30 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 3!!!
SEVERE [01:21:32 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 7!!!
WARNING [01:21:48 26-Mar-25 IST][bacnet.network] Possible network number mismatch: received network-number-is: "1", on port whose network number is "11"
SEVERE [01:21:48 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 8!!!
SEVERE [01:21:48 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 7!!!
SEVERE [01:21:48 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 4!!!
SEVERE [01:21:48 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 1001!!!
SEVERE [01:21:48 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 16!!!
SEVERE [01:21:48 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 1003!!!
SEVERE [01:21:49 26-Mar-25 IST][fox] Failsafe timeout on read 60656ms > 60000ms
SEVERE [01:21:48 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 9!!!
SEVERE [01:21:58 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 1004!!!
SEVERE [01:22:21 26-Mar-25 IST][fox] Failsafe timeout on read 78047ms > 60000ms
SEVERE [01:22:05 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(4): Possible router loop, or duplicate network number 11
SEVERE [01:22:50 26-Mar-25 IST][fox] Failsafe timeout on read 87750ms > 60000ms
SEVERE [01:22:52 26-Mar-25 IST][fox] Failsafe timeout on read 80891ms > 60000ms
SEVERE [01:22:52 26-Mar-25 IST][fox] Failsafe timeout on read 99813ms > 60000ms
SEVERE [01:22:50 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(4): Possible router loop, or duplicate network number 11
SEVERE [01:22:52 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 10!!!
SEVERE [01:22:52 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 1095!!!
SEVERE [01:22:52 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 1!!!
SEVERE [01:22:53 26-Mar-25 IST][fox] Failsafe timeout on read 86641ms > 60000ms
SEVERE [01:22:55 26-Mar-25 IST][fox] Failsafe timeout on read 67890ms > 60000ms
SEVERE [01:22:53 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 17!!!
SEVERE [01:23:15 26-Mar-25 IST][fox] Failsafe timeout on read 67360ms > 60000ms
SEVERE [01:23:28 26-Mar-25 IST][fox] Failsafe timeout on read 80907ms > 60000ms
SEVERE [01:23:18 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 12!!!
SEVERE [01:23:48 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 15!!!
SEVERE [01:23:48 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 3!!!
SEVERE [01:23:48 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (15ms) indicates possible router loop on network 14!!!
SEVERE [01:23:48 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 18!!!
SEVERE [01:24:08 26-Mar-25 IST][fox] Failsafe timeout on read 95813ms > 60000msSEVERE [01:23:48 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 6!!!
SEVERE [01:24:18 26-Mar-25 IST][fox] Failsafe timeout on read 81125ms > 60000ms
SEVERE [01:24:35 26-Mar-25 IST][fox] Failsafe timeout on read 61046ms > 60000ms
SEVERE [01:24:40 26-Mar-25 IST][fox] Failsafe timeout on read 104312ms > 60000ms
SEVERE [01:24:23 26-Mar-25 IST][bacnet.network] Bacnet Network Misconfiguration detected(3): Network number update frequency (0ms) indicates possible router loop on network 13!!!
SEVERE [01:25:34 26-Mar-25 IST][fox] Failsafe timeout on read 145656ms > 60000ms
SEVERE [01:25:59 26-Mar-25 IST][fox] Failsafe timeout on read 75500ms > 60000ms
SEVERE [01:26:33 26-Mar-25 IST][fox] Failsafe timeout on read 69391ms > 60000ms
SEVERE [01:27:35 26-Mar-25 IST][fox] Failsafe timeout on read 66813ms > 60000ms
SEVERE [01:29:32 26-Mar-25 IST][fox] Failsafe timeout on read 67109ms > 60000ms
SEVERE [01:31:06 26-Mar-25 IST][fox] Failsafe timeout on read 61860ms > 60000ms
SEVERE [01:32:43 26-Mar-25 IST][fox] Failsafe timeout on read 66641ms > 60000ms
SEVERE [01:34:12 26-Mar-25 IST][fox] Failsafe timeout on read 69282ms > 60000ms
SEVERE [01:35:23 26-Mar-25 IST][fox] Failsafe timeout on read 63422ms > 60000ms
SEVERE [01:36:58 26-Mar-25 IST][fox] Failsafe timeout on read 60141ms > 60000ms
SEVERE [01:38:54 26-Mar-25 IST][fox] Failsafe timeout on read 69203ms > 60000ms
SEVERE [01:40:11 26-Mar-25 IST][fox] Failsafe timeout on read 97063ms > 60000ms
SEVERE [01:41:36 26-Mar-25 IST][fox] Failsafe timeout on read 103250ms > 60000ms
SEVERE [01:46:17 26-Mar-25 IST][fox] Failsafe timeout on read 102125ms > 60000ms
SEVERE [02:01:03 26-Mar-25 IST][fox] Failsafe timeout on read 234953ms > 60000ms
SEVERE [02:07:25 26-Mar-25 IST][fox] Failsafe timeout on read 1059485ms > 60000ms”
