Hi,
I’m looking for some best practice methods for the reporting I have in mind.
I have a large site with around 50 buildings. Most buildings have a boiler.
I would like to pull a report with both the BoilerEnable & BoilerFlowTemp from each building appearing. The report would have columns like:
BoilerEnable | Boiler Flow Temp|StationName?|
Would a ComponentGrid be best?
Howdy and welcome! I can answer more when I get back to the hotel but that is an option. I’ll go over more when I get back from my meeting.
Thank you Charles, great help as usual! (Follow you on YouTube & LinkedIn
Can you share your nav tree structure? This will help determine how/if BQL is the best solution. Having a common naming convention or folder structure to work with will help
Unfortunately there is no proper structure but this can be fixed. How would you suggest for this to work best?
Currently it’s:
Niagara Network
Building 1
Points
BoilerEnable
BoilerFlowTemp
Building 2
Points
BoilerEnable
BoilerFlowTemp
Thanks Giantsbane
How are back does the information need to go? Like are we talking about snapshots of specific times are just a snapshot when generated?
Just a snapshot, exported at 2am using export source.
OK. I’m in the airport on my last leg. I will address this tomorrow with some screenshots
@thatboyniagara
Sorry for the delay in response! Busy with trainings and such. Since today is Saturday and I leave tomorrow, today is the best day to answer this!
So you have many options here and what you want to do would be your choice.
First, you could create a reportPX which would allow you to set it up in this particular format:
Each Section header has a value Binding with the ORD of the NiagaraStation with an animation of %displayName%
Each Bound Table is a BQL query against the station itself with the following:
The Scope changes for each station, so after duplicating them, I just changed the station name.
Here is a sample query of that:
station:|slot:/Drivers/NiagaraNetwork/BuildingDemo|bql:select displayName as ‘Point Name’,out.value as ‘Point Value’ from control:ControlPoint where name like ‘Boiler%’
Instead of doing a component grid, you can do a BQL grid instead:
The result would be exactly like you explained it:
An example query for that would be this:
That would be this:
station:|slot:/|bql:select displayName as ‘Station Name’,points.BoilerEnable.out.value as ‘Boiler Enable’,points.BoilerTemp.out.value as ‘Boiler Flow Temp’ from niagaraDriver:NiagaraStation
NOTE: My query is based on my points being directly in the points container. You would have to use points.PointsFolder.PointName.out.value If that makes sense. What I mean is wherever they are located, which would be in a Points Folder under the Points Container of the Niagara Station.
I hope this all helps
Thank you Charles, really appreciate this!
No worries about the delayed response, was worth it
