Wiring BACnet sensor and workbench setup
Hi guys…
im happy to find you by grok and see this big community in Tridium Niagara
i want to add one temprature sensor on my jace 9000 device
but i dont want sale it before sure about ability to its possible to wiring and reading that data in workbench
the “Siemens QAA2235.EWSN” sensor by researches, is good
but i have some questions:
1- is this sensor good to connect to the jace 9000 tridium niagara?
2- is anything necessary with this sensor? (hardware or software or any programs to load ob workbench)
3- can you give me a shematic of wiring the jace with sensor?
4- anything you know to important for me and good to i know…
thanks a lot
Do you have an IO module to attach it to? Like a NRIO34 or 16?
If I’m not mistaken that’s a 100K ohm sensor.
You would need to get the resistance chart for it and make it a tabular thermistor. Then import that XML into workbench.
Chat Gippity would be perfect for that.
thank you for your help
yes its 100k ohm
the AI images creators are not suitable and strong in creating diagram of wiring
i think its so helpful if you give me a pic of your wiring on the paper…
im beginnner and not have good knowldge
So that’s not as easy depending on what you have exactly. If it’s a sensor only then you only wire the + and - of the controller to terminals 2 and 3
