Jace 9000 Ethernet ports - Secondary not working
I searched the content of this site so hopefully no one has asked this question.
We have a Jace 9000 where we are using the primary ethernet port for the customers internal network and we are using the secondary port to access the Jace with a remote device. We can log into the Jace on the primary, plugged directly into it, and “see” the secondary port from the remote software client page but cannot connect remotely. I have read a blog online about the ports share a gateway and the first port to use it, will block the other ports gateway.
Is there a fix to this where we can have two gateways used at the same time or has anyone else figured out a work around for this?
Thanks all!!
The short answer is no. It only takes one of them. I think it was a mistake to have them show both. It will only take one, whichever gets there first.
Thanks, Charles for the response
Much appreciated. I
https://www.niagara-community.com/s/article/Do-not-configure-Default-Gateways-on-both-Ethernet-Adapters-on-a-JACE-9000
