Right Click not working
I’m running a backup of 4.13 Niagara Station locally on my workbench. I’m not able to rightclick any of the Writable blocks.
ie. BooleanWritable is not right clickable but BooleanPoint is. I need to link the writable to a schedule.
Never ran into this issue before so I’m not sure what to make of it. Can confirm that station is 4.13 and I’m running it on 4.13.
I also tried creating a Writable in Apps folder and that is also not right-clickable.
Hey @Boba
Just ticking off the obvious stuff:
Yeah, all good on permissions and flags. I checked category service as well. I’ve reviewed user settings, I have the admin role. Everything seems to be in place. When i right click, nothing happens. No menu shows up
Update: Right clicking works on any view that is not AX.
Update 2: Apparently, link marks in Ax view are not carrying over to non ax views. ie, I linkmark a schedule in axWiresheet, goto a point in Property Sheet view. Upon rightclicking, the previously link marked point will not appear on the menu. and vice versa.
Sounds like one of those problems, where I would do a reinstall of the workbench, before diving too deep into the cause of it.
Yeah, Just tested on a different live site and saw the same issue. I installed 4.15 yesterday and i wonder if that has something to do with this issue popping up. This wasn’t a problem in the past.
I’m going to do a reboot and see if that fixes it. if not, I’ll go for a reinstall.
Restarting didn’t work. Reinstall did work.
